so i have the linksys ea8500 and an xfinity modem/router and i just want to use the linksys one for a router and when I'm on the xbox or something the connection sucks!!
please help me. i know the linksys modem is fast but i don't know. Also the linksys emits a wifi signal and i don't know what to do so plz help!!
https://linustechtips.com/topic/644332-help/
I had this same exact problem.
You have to get a small Ethernet patch cable and run it from the modem to your router and set up the router like normal.
hope I was able to help.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/644332-help/#findComment-8296189
sooo i just take a normal ethernet cable plug it into one of the xfinity ethernet ports and put that into the internet port on the router?
https://linustechtips.com/topic/644332-help/#findComment-8296206
You'll need to put the Comcast router/modem into bridge mode since you want to use an other wireless router. You'll need to do this in the config of the Xfinity device by entering the IP address of your actual gateway in a web browser something like 192.168.0.1 or 192.168.1.1. You could contact your ISP if you're not sure were to go to turn it in bridge mode.
Once it's done, run an Ethernet cable from one of the LAN port of the Xfinity modem/router to the WAN port in your Linksys router.
So now the Linksys Router is acting like your router/switch/firewall and the Xfinity device only has a modem like you want.
https://linustechtips.com/topic/644332-help/#findComment-8296245
  • 4 weeks later...
hey thanks :) anything else i should do?
https://linustechtips.com/topic/644332-help/#findComment-8512111
