Hey Guys, i recently updated my Msi Motherboards bios..i flashed my bios when the switch was on 1st bios (main bios) ..now my question is ..should i repeat the flashing procedure with the switch on the 2nd bios also???? since i have a multi bios motherboard...(z97 gaming 7 )
https://linustechtips.com/topic/644260-multi-bios-update-help/
Only if the main bios took and works properly, the point of the second bios is to be a back up to prevent bricking the motherboard
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/644260-multi-bios-update-help/#findComment-8295469
2 minutes ago, Shaun56 said:
I tried booting my motherboard from the second bios and it dosent boot
Well then there is no reason to keep the old one then is there, I assume the main bios boots properly, if so go for it
https://linustechtips.com/topic/644260-multi-bios-update-help/#findComment-8295484
