I plan to mod my Corsair Carbide Spec-01 case side panel, changing it for acrylic/plexiglass.
The idea came when I saw the new Phanteks cases with Tempered glass side panels.
For now I made a project in photoshop, but I need advices from people who have experience with this, I need to know the thickness of the acrylic, how to mount it and how to tint it.
Here's the photoshopped picture:
System: |Intel Core i5 4690K|ASRock Z97 Anniversary|2x4GB Kingston HyperX Fury 1600Mhz RAM|Sapphire Radeon RX 480 Nitro+ 4GB|Phanteks P400S TG Edition (First ever owner!)|Seagate 1TB HDD+WD Blue 620GB|Seasonic M12II-620 EVO 620W 80 Plus Bronze Modular|Cooler Master Hyper 212 EVO|
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/
-PIC-
That looks good, for something like this you will probably want to purchase colored/tinted acrylic directly, for the thickness you will want to keep it pretty thin something like 1/8" would be good especially if you chamfer the edges so it matches a similar thickness to the original side panel. For mounting you have a couple of different ways to go about it either to have it bolted through with bolts/thumb screws or to make something magnetic and latch it in place.
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8286724
What would be needed to chamfer the edges?
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8294705
Also, I stamped into a problem.
The Cooler Master Hyper 212 EVO sticks out a little (milimiters) out of my case, and since the side of the case is a little bulky it fits.
Don't know how it's gonna be with the acrylic, how could I solve this problem?
I can send you pictures of how much it sticks out if you want.
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8295428
For chamfering you could use a file and some sand paper, as for the cooler though  if it sticks out past where the case panel is you could either make a raised portion to accommodate for it or a slightly shorter cooler.
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8296658
What do you mean by raised portion?
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8297622
The original panel has a bumped out or raised portion out a bit to give it that extra room needed for the cooler so could make something similar to give it that extra clearance if the heatpipes impact the window.
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8297645
If it's just the heat pipes that stick up you could also cut holes in the acrylic right there if you wanted. Up to you though.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/643194-acrylic-side-panel-mod/#findComment-8298106
