I've just built a new computer and the CPU fan Pin makes any fan or liquid cooler I plug into it run at an extremely high RPM
In the screenshot you can see CPUFAN is at 4500 RPM and it sounds like a jet engine.
Its also the exact same speed from when i turn my computer on to when i turn it off and there is no difference when gaming.
The motherboard is a "ASRock H97M-ITX/ac" and the cooler is a Corsair H60.
Any idea what i could do or even there is a fault on the motherboard?
https://linustechtips.com/topic/643185-cpu-fan-too-fast/
go into your BIOS and turn it down....
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/643185-cpu-fan-too-fast/#findComment-8284332
are you saving your BIOS setting?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/643185-cpu-fan-too-fast/#findComment-8284351
the fan controller might be disabled, also try using speedfan if you cant fix it in the BIOS
Builds:
https://linustechtips.com/topic/643185-cpu-fan-too-fast/#findComment-8284381
