How are these temps? Of course with respect to the clock speeds is it reasonable?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/642678-290x-load-temps/
That is safe! :)
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279194
It's perfectly fine for a GPU
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279201
10 minutes ago, Abdul201588 said:
That is safe! :)
9 minutes ago, Ichi said:
I would be okay with 82 degress any day on that card.
Really? :o I thought it was like scalding hot!
so 82c is actually fine? :D
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279217
perfectly fine, the r9 x90 series goes up to 95 degrees before throttling. had a 290 reference running at 94 degrees before :P
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279240
15 minutes ago, Ichi said:
82c at 100% load is fine.
That's a 290x we're talking about.
If it's GTX1070/GTX1080 then I would consider it hot.
290x vs gtx 480? Which is the hotter card? :P
But i usually see in benchmarks they only go up to 70~c D:
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279249
GTX 480s ran at 100*C in my experience. 80*C is nothing
Those are with high end 290Xs like the Vapor-X or Tri-X
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279250
the 1080 FE runs at 85*C
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279251
i see his sig and it looks like a tri-x r9 290x :P
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279255
Im running a tri-x!
Yeap D: Is it bad now? :C
In what ambient? My current ambient temps are 32c!~
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279257
higher than average it seems, judging from this:
https://www.techpowerup.com/reviews/Sapphire/R9_290X_Tri-X_OC/28.html
but should be fine. try the reference cooler than you'll know all about 'bad' with hot AF hawaii
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279263
My 290x idles at 55c D:
I cant even imagine a blower style with this card xD
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279274
my 290 used to idle at high 50s-low/mid 60s, and 94 at load in just 2-3 minutes.
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279281
13 minutes ago, xnoobftw said:
Im running a tri-x!
Ambient is high. At 22*C it would be much lower.
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279290
So 82c is actually good for 32c ambient? :o
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279300
when you only live just above the equator :/ always sweating like a marathon runner whenever i reach nearby school...
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279302
Do you too? :P I sweat like crazy even at home xD
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279339
Yes. ambient temps directly affect core temps. If you were at 22*C idle then your temps would be around 75*C (what I expect from the Tri-X 290X)
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279346
Alright thanks!
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279360
25 minutes ago, xnoobftw said:
Alright thanks!
Do you have airflow in your case btw?
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279484
2 filtered intakes (1 stock case fan + 1 quiet edition SP120) running at 100% at all times in the front
2 top exhaust high performance SP 120s which ramps up to 50% when gpu reaches above 65c, otherwise it is off
1 rear exhaust stock case fan which ramps up to 50% when gpu reaches above 65c, otherwise it is off
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279515
Adding a bottom intake would improve GPU temps a LOT. I remember the MSI 390/390X needed a bottom intake fan to reduce temps by 5*C
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279655
the evga g2 850w is too big for a bottom intake D:
I do have a 80mm fan that is able to fit tho... Should i install it? :o
https://linustechtips.com/topic/642678-290x-load-temps/#findComment-8279683
