I am going to upgrade from my crappy AMD PC that is about 4 years old, not sure how old though, I am going to upgrade the CPU, CPU Cooler, Motherboard, RAM and GPU!
I make YouTube videos and I stream, so that made me go for the i7 6700 I don't have a CPU Cooler as of now so I went for the Corsair h100i v2.0 I am not sure what motherboard to go for, so suggestions are appreciated (I am from the uk so £ please)! 16GB of RAM is what I am going for but obviously that depends on my motherboard what speed I can go for. I was originally going to go for the GTX 1080 but I found out that I don't really need that because of the games I play (I'll explain further down) so I said 'Ok I won't go for the GTX 1080 what about the 1070?' this is where I need some help, because I only play CS:GO, COD: Black Ops 2 and The Forest so I don't need a GTX 1080 because that is a bit overkill but the GTX 1070 I'm not too sure about.
So basically all I am asking what GPU should I go for, I want a decent one, preferably something from 2016 or late 2015. Something that gets good FPS at 1080p on all games but isn't more than £500 (that's for the GPU) *man I am so stressed about this!!!* now for the motherboard please don't go above £95 *man it sounds like I am using them but I am not!* I just need a lot of help on this! So in conclusion I would love some suggestions on what GPU to get under £500 and what motherboard to vet under £95 and the GPU can run most games at 1080p but it would a card i wouldn't need to upgrade for a few years!
Thank you for all your help! I am so appreciative of it I am just really stressed out thank you once again! <3 <3
What I going for:
CPU - i7 6700
CPU Cooler - Corsair h100i v2.0
Motherboard - I don't know
RAM - 16GB not sure what brand yet
GPU - Not sure,
READ ABOVE TWICE FOR INFO SO DON'T REPLY STRAIGHT AWAY
https://linustechtips.com/topic/642640-i-need-help-please/
Motherboard: Gigabyte G1 Sniper B7 (B150 chipset)
GPU: Asus ROG STRIX GTX 1070
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278862
2 minutes ago, Lewiskyy said:
so a GTX 1070, really?
Well if you want yo spend 500 pounds on a GPU, this is your best bet, but since you'll only be doing 1080p, a GTX 1060 can also be an option (look for some benchmarks on youtube) that will not perform as well, but can save you some money
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278878
1 minute ago, Lewiskyy said:
No color scheme at all,so a GTX 1070, really?
You would be fine with a GTX1060 but since you have the budget for it, I would just say take the jump to GTX1070 right away.
GTX 1080 is super overkill for your needs so there's that.
For mobo, take a look at this, http://uk.pcpartpicker.com/product/NsL7YJ/gigabyte-motherboard-g1sniperb7rev10.
That's one of the cheapest board that you can get at £70.
There's alot option below £95 though.
If you need other suggestion or you just don't like green, let me know.
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278879
Ok, so the GTX 1070 is what i will go for (thanks for that) green wouldn't really suit my build because I have a white case and GPU's aren't often green xD and yeah, just no for green :)
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278881
http://uk.pcpartpicker.com/product/NdmxFT/msi-motherboard-b150pcmate
Go for that then, color neutral.
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278884
2 minutes ago, (C)ry_W(a)r said:
or like an 960 or heck 2 960's if u want to be a boss. Honestly i get around 40-50 fps on CSGO with a 750ti 2 gb so really you have a lot of options. you could also save money on the graphics card and spend 4 a better motherboard
Really? i have a 650ti 4gb of ram and a duo core and i get over 60fps on CS:GO
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278919
1 hour ago, (C)ry_W(a)r said:
I also have a duo core. BTW what temp does your cpu/graphics card run at. Also what do u use 4 fps. Geforce Exp. just ain't cutting it.
It runs at 27c at idle and 40-60c under heavy load. And you can overclock with MSI Afterburner if you need some extra juice ;)
Yeah i play it sometimes when i feel like a change ;)
Edited by Godlygamer23
https://linustechtips.com/topic/642640-i-need-help-please/#findComment-8278928
