So randomly out of nowhere my pc stated "Your PC has ran into a problem and will restart now" it restarted fine & its working good again. At the time it said that I only had 3 tabs and skype open, and my PC is custom build and has 8 gigs of ram and an i5 so i dont think that would be an issue. I was thinking it may have been my hard drive its just a normal 1tb drive not SSD. Do you think this was the issue and if so should i get an cheap SSD like $50 120gb SSD to put windows on, do you think that will fix it ?
https://linustechtips.com/topic/642498-your-pc-has-ran-into-a-problem-question/
Just now, Zeako_ said:
it has happened one time in the past, but last time it happened everything on my drive got deleted, not sure
yea, without the error code, impossible to know what caused it and how to prevent it.
just remember to look at the code,
pic or write it down so you have it.
