Ok well so I wanted to reset my pc but when I did it said that window could not refresh pc no changes have been made, so I went into the USB troubleshoot start up thing and then tried to reset it there but it said it didn't work so when that happend I tried to turn on my pc. Then my pc had this error when starting up.
https://linustechtips.com/topic/642367-help-with-pc-startup/
4 hours ago, MemeKid_Nub said:
Where do I do that? If it's in the boot menu I can't do it because when I press esc it won't go to the boot menu.
Is it here in this picture?
In standard cmos features, or advanced bios features.
Troubleshooting a pc will make you believe in gremlins.
--Thread killer--
https://linustechtips.com/topic/642367-help-with-pc-startup/#findComment-8277621
