3 minutes ago, nipplesalad said:
I'm building a pc with a 6800k, what do you guys think is the better cooler?
Noctua NH-U14S or the Cryorig H5 Ultimate
thanks
i'd go noctua. it looks like they perform about the same...
https://www.techpowerup.com/reviews/Noctua/NH-U14S/6.html
http://www.hardwareslave.com/reviews/hardware/cooling/cryorig-h5-ultimate-cpu-cooler-review/3/
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/642198-6800k-cooler/#findComment-8274488
The Noctua NH-U14S cools slightly better. The CRYORIG H5 Ultimate isn't exactly bad either though if you care about looks.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/642198-6800k-cooler/#findComment-8274502
The NH-U14S is better.
https://linustechtips.com/topic/642198-6800k-cooler/#findComment-8275510
