My friend has a Lenovo A1000 and he did something to this phone to hack pokemon go and now the phone always boots in TWRP ( a recovery program ). From what he told me, he said that he needs to install a OS in the phone. We tried something from youtube and forums but it did not work. This is the story in a few words.
Can someone suggest something, or a program or I don't know.
Thank you. :3
https://linustechtips.com/topic/641772-os-phone-problem/
try re flashing it with is's original kernel then re-flash it with the new one, then install the os it's should boot into the os no problem, if your still having problems maybe bring it up on TWRP's forums see if they can help
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/641772-os-phone-problem/#findComment-8271873
Either get the original firmware  from the lenovo website and follow instructions  or
Download a rom for the phone,  put it on the storage using a usb cable and use twrp to install it (flash).
I assume that if he has twrp installed he already has an unlocked bootloader.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/641772-os-phone-problem/#findComment-8272072
