Hey guys!
I know this topic is here many times, but I would like to ask it again.
I am thinking of Obsidian 750D case, which has pretty big side window. I really want to use some LEDs in the case, and also behind the desk and the monitors. I found many methods, and that did kinda confuse me.
What tips can you give me and basically, what method would be the perfect? Easy and efficient at the same time.
Thank you so much in advance.
https://linustechtips.com/topic/641747-led-lights/
Any LED strip will offer the least amount of space taken in the most inconspicuous space.
I use two Cold Cathode tubes which work well but aren't hidden as well.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/641747-led-lights/#findComment-8270053
3 hours ago, 4kliksphilip said:
Hey guys!
If you wanted to DIY something you could get those LED kits off Amazon but for a finished solution, you could get LED's from Cable Mods or Addon Customs who has a kit specifically for this kind of setup.
https://linustechtips.com/topic/641747-led-lights/#findComment-8270911
We have both RGB and single colour, multiple LED strip lengths, loads of cable lengths and sleeving colours to choose from, if you still don't see exactly what you want you can pm us or submit a ticket on our site and we will work with you to get what you want.
You can check out our site here > https://addoncustoms.com/
We ship worldwide at low prices. All LEDs are wired and sleeved by hand and tested before being sent.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/641747-led-lights/#findComment-8273774
On 8/11/2016 at 11:37 PM, 4kliksphilip said:
Hey guys!
check Luke's video about our LED Strips:
https://linustechtips.com/topic/641747-led-lights/#findComment-8277708
Wow, I am really happy to hear so many replies! I think I figured out how to do it.
But the last question, what about connecting them to a power source? I mean, having some in case and behind monitors and the desk at the same time and connecting it where?
Maybe if I did connect some in PSU and did find some strips with adapters for the rest ones? Might this be my very solution?
https://linustechtips.com/topic/641747-led-lights/#findComment-8279122
With ours we can make the LEDs in the case have a short power cable, and the monitor and desk lights can have a power cable a couple of meters long, and you can choose between Molex or Sata and they can all plug inside your system, so when you turn on your computer all the lights come on at once, or you can just use a 12v wall adapter for the desk/monitor leds, which we don't sell but can help you find one.
Addon Customs -
https://linustechtips.com/topic/641747-led-lights/#findComment-8279140
