I've been experiencing a weird problem with my headphones on my PC. It's been happening for  a while on and off. Randomly when I put on my headphones,
sound only comes out the right side. I opened up my case and made sure all the connections to the front audio are tight. I jiggled the cables around a bit because why not right?
One side is not muted in the audio settings and they work fine with any other device AND the PC 90% of the time.
What would be causing this?
- It fixes itself after restarting the computer 1-3 times or patting / complimenting the PC.
Corsair Air 540 - ASUS Maximus VIII Hero Z170 - Corsair HX850i - Intel i7 6700K - Corsair H100i Pro - Gigabyte RX 5700 XT 8GB - 32GB Kingston HyperX Fury DDR4 2400 - Samsung 860 QVO 1TB - Samsung 850 500GB - WD Black 4TB
https://linustechtips.com/topic/641629-random-headphone-problem/
hmm. i had / have a issue where my headphones get muffled, i found updating the drivers worked but that was with rear 3.5 plugs not the front audio. hard to say how u can test this as im not sure if MB these days have 2 front audio MB slots.
Faith: WIP
Cpu: intel 6700k
RAM: g.skill ripjaw v 3200mhz 16 18 18 38 2n 32gb 4x8gb
MB: Asrock extreme 7+
GPU: GTX 1080 TI Poseidon Platinum Asus ROG
PSU: Cougar 1050W 80+ gold
Case: IN WIN 509 ROG [ black red ]
Cooling: Barrow Fittings, Block, 360mm x 60mm rad, 18w d5 pump, 210 res, EK blood red premix. Poseidon GPU block
SETUP: BenQ 27" 144hz|BenQ 28" 1080p VA 60HZ|Corsair Strafe RGB|Razer DeathAdDer Chroma|ATH IM70|E10k Olympus 2 amp|DX Racer King
https://linustechtips.com/topic/641629-random-headphone-problem/#findComment-8268893
