Posted August 11, 2016 The votes will be used as part of a business report I'm writing about Apple's success and failiures. Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2016 You can do so much more on a surface than an ipad because of windows. iPad pro is just an excuse for a larger ipad. [Case Mod] Operation: The Division --- > Here [CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here -== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==- Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8268472 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2016 Surface pro 4. iPad needs to have some multitasking functionality (for example, "OS Experience" for iOS 7, jailbreak tweak) that is useful. I mean -- All that power and yet it can't be used. However the surface pro 4 is running a full version of windows 10 which makes it way more useful and isn't limited to applications in the app store only. Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017) Samsung 850 EVO 240 GB 138 is a good number. Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8268473 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 14, 2016 If you're using it for illustration, go for the iPad Pro. Otherwise, if you need a desktop environment and decent art capabilities go with the Surface Pro 4. Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8282598 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 14, 2016 How about none??? /s If it is not broken, let's fix till it is. Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8282812 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 14, 2016 If the iPad Pro weren't a joke there might have been some thought involved on my end LOL. If they wanted the iPad Pro to be a viable option for "professionals" they should have put OSX on it! - Personal Rig - AMD 7950X3D / 64GB G.SKILL DDR5-6000 EXPO / ASUS RTX 4090 TUF OC ASUS ProArt X670E / Noctua NH-D15 / Corsair 4000D Airflow / Corsair RM1000x / 4 x 2TB Crucial P5 Plus - HW Graveyard - MSI GTX 780 Lightning 3GB Dec 2013 - Dec 2018 Seasonic Platinum 1000W Dec 2013 - Dec 2018 PNY GTX 470 1280MB June 2010 - August 2017 Intel Q9550 / Q9450 Systems Q1-2008 - Q3-2016 - Desktop Audio Equipment - ADAM Audio F7's | Topping D30 Pro | Topping A30 Pro | HD598 & HD6XX w/ Sheepskin Pads Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8282968 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 14, 2016 I never saw the need for the iPad Pro, in my eyes it's a big expensive Apple product that doesn't do as much as a mac. If they had put a version of Desktop OS like windows had done it might have been a more appealing product for me. Link to comment https://linustechtips.com/topic/641523-surface-pro-or-ipad-pro/#findComment-8284000 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
