CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($226.79)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($38.15)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($91.79)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2133 Memory  ($68.65 @ Newegg)
Storage: Silicon Power Slim S55 240GB 2.5" Solid State Drive  ($63.20 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($74.56 @ Amazon)
Video Card: Zotac GeForce GTX 1070 8GB AMP! Edition Video Card  ($485.72 @ Newegg)
Case: Corsair 330R Blackout ATX Mid Tower Case  ($88.08 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($88.62 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($28.00)
Total: $1253.56
Generated by PCPartPicker 2016-08-09 20:12 EDT-0400
What is your intended use for this build?
Casual computer use like Web surfing & Microsoft word. I also do some photo and video editing.
If gaming, what kind of performance are you looking for?
Right now I would be gaming on a resolution of 1920x1080, but I would like to upgrade to 4k soon. I don't want my computer to limit the games I can play. I would like high to medium settings with the lowest fps being around 45.
What is your budget?
$1300 is my max budget.
Other/miscellaneous
I want my computer to be as quiet as possible, and cool as possible. Aesthetic don't matter a whole lot to me. I am planning to so SLI later so I want to keep that door open. I would like my PC to be on the smaller side but that isn't necessary.If you could recommend better parts but stay within budget I would appreciate it. Thank you.
https://linustechtips.com/topic/640851-first-computer-build/
Total: $1253.56
Other/miscellaneous
You'll want an i7 if you want to do video editing and such:
PCPartPicker part list: http://pcpartpicker.com/list/R3Qqpb
Price breakdown by merchant: http://pcpartpicker.com/list/R3Qqpb/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($332.79 @ B&H)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  ($82.98 @ Newegg)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($59.99 @ Adorama)
Storage: PNY CS1111 240GB 2.5" Solid State Drive  ($59.99 @ Best Buy)
Storage: Hitachi Deskstar 2TB 3.5" 7200RPM Internal Hard Drive  ($62.70 @ Amazon)
Video Card: Zotac GeForce GTX 1070 8GB AMP! Edition Video Card  ($438.99 @ B&H)
Case: Corsair 330R Blackout ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Rosewill 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1253.57
Generated by PCPartPicker 2016-08-09 20:34 EDT-0400
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261134
This looks great, not much I can really reccommend, but you did a great job deciding parts for this build. A 1070 should do a great job of 1080p gaming, or even 2k. 4k is great but doesnt offer the great refresh rates 2k does. Id reccomend a 2k over a 4k since those refresh rates are really going to give you the best experience.
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261139
Total: $1253.57
I edit on my i3 lmao
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261144
Total: $1253.57
The extra cores would be nice in video editing, but you did go over my budget.
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261201
PCPartPicker part list: http://pcpartpicker.com/list/FHFGqk
Price breakdown by merchant: http://pcpartpicker.com/list/FHFGqk/by_merchant/
Video Card: Gigabyte GeForce GTX 1070 8GB Mini ITX OC Video Card  ($385.99 @ SuperBiiz)
Total: $1200.57
Generated by PCPartPicker 2016-08-09 20:48 EDT-0400
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261210
33 minutes ago, Starelementpoke said:
But how fast do you do it?
Render? 720p30fps is a 1:1 ratio, 1 minute per 1 minute of footage.
https://linustechtips.com/topic/640851-first-computer-build/#findComment-8261308
