Will my case fit this cooler
DAnewguy
In my case specs it says max hight of cooler 160mm and the cooler is 160mm will it fit
If it says it will... it should.
"Anything that could one day be is as real as what I'm saying
If something is nothing it must not be something in any possible way"
-John Frusciante
Yeah idk I mean if it is like 1mm to long I'm fucked
Normally that "max" has some extra space to it. What it means is that the max size of a cooler you can fit in is 160mm, but that doesn't make the area 160 mm. It's probably got enough space. What is the case you have and the cooler you want?
-John Frusciante
Phanteks eclipse p400s case and
Cryorig h5 universal Cooler
So yeah it would look a bit close to the side panel I'd say. But other than that it should fit
-John Frusciante
Well I think it will look good with a big ass cooler I hope atleast
It should lol
-John Frusciante
