Hi I just overclocked my 6700k to 4.7 ghz and the temps are ranging from about the high 60s to lower 70s on stress test is this good? I used xmp, and I changed the voltages to lowest possible on 4.7 ghz, are these temps too high because before overclock the temps were 80c
https://linustechtips.com/topic/640114-cup-temps-after-overclock/
That is fine. During stress testing as long as you keep temps ~75c your golden.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
As long as you keep voltage under 1.4v with adequate cooling your good.
Community Standards
"Beast Mode"
ummmm... 2.7v??? FIRE ALERT... How is your CPU not dead...
Community Standards
"Beast Mode"
Your vcore should never be above 1.4v for 24/7 operation with a 6700k...
Community Standards
"Beast Mode"
ok, 1.27v and your stable at 4.7ghz?? damn.. good job.
Community Standards
"Beast Mode"
When I run Aida64 I am around 70c and Intel Burn Test usually around 80-85c which im fine with because its a burst test, not sustained.
Community Standards
"Beast Mode"
Yea, as long as you can run stable for 30m-1hr is what I personally strive for you should be good.
Community Standards
"Beast Mode"
