which power suply should i get for theese + keyboard and headset?  And are they compadable?
Aerocool V3X Advance
Crucial 8GB (2x4GB) DDR4
ASUS E3 PRO V5
Intel® Core™ i5-660
GTX 650
Seagate Momentus ST160LM003 8MB 160GB
Kingston SSDNow mS200 SMS200S3 30GB
https://linustechtips.com/topic/640042-please-help/
The case is fine
The RAM should be fine
The motherboard is fine
That CPU will NOT work with the motherboard. You need a CPU that is socket LGA1151
Although old the graphics card should work. Don't expect a good gaming experience though.
The hard drive will work but I'd go with something else. That HDD is overpriced.
That M.2 based SSD will not work with the motherboard.
As for PSU I'd get anything 650W+ from CORSAIR, EVGA, maybe SuperNOVA don't quote me on that. Just make sure it says 80 Plus Certified.
https://linustechtips.com/topic/640042-please-help/#findComment-8253072
