Which temps should I trust?
Solved by LeStringMan,
Go by Overdrives numbers, but keep in mind it measures thermal margin, so you are 43.6 degrees away from your max temp in that screen shot.
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
