Is it advisable to not use the CPU fan header for the radiator fans?
im using SpeedFan for custom fan curves.
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
https://linustechtips.com/topic/639822-fan-headers/
its the same thing. :P
but you should use the CPU fan on the CPU header.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/639822-fan-headers/#findComment-8250606
but my i cant control cpu fan header with speedfan.im planning to use the cpu fan header on my exhaust fan and the other header for radiator fans
https://linustechtips.com/topic/639822-fan-headers/#findComment-8250616
