I have a gtx 960 4gb and i7-2600 about 2 weeks ago my fps just randomly went from 300 to 150 on high. Then I configured all my nvidia settings yet I still get that same 150 sometimes lower or higher fps on csgo no matter high medium or low. On 1v1 community arena i get like 350 fps so I don't understand. I cleaned my pc a few days ago and things are still the same but with some freezes that last about 2 seconds now. My temps and clock speeds are fine so I don't know what to do.
Edited by Glenwing
Removed caps lock from title and fixed formatting
https://linustechtips.com/topic/639692-fps-sudden-drop/
Reinstall drivers?
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249188
Just now, addoracsgo said:
which ones?
Nvidia?
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249198
1 minute ago, GSTARR said:
reinstall video drivers is my best guess
150fps is pretty swell... although if its occurring in other games then it's certainly a problem
In CS:GO you want 200fps all the time. It has to do with input lag. 60fps in CS:GO is basically unplayable.
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249202
ok i'll let you now.
Install 361.75. Those are 100% stable.
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249209
Just now, GSTARR said:
i use 60 fps rip fite me
peasant :D
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249218
2 minutes ago, Lord_Doge said:
dat 5 year old cpu tho.
Make sure you gpu isnt throttling. I've had mine do it for no apparant reason before
2600 still is a good cpu lmfao but my gpu is at its normal clock but as soon as i alt tab it goes back to idle clock and vise versa
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249232
gonna go try it out and see the difference for mahself
200fps vs 60fps. Several miliseconds input difference
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249241
Just now, Lord_Doge said:
you cant tell me you can tell the difference between ~10ms latency
Try CS:GO. It's VERY noticeable when you die before you even shoot. It's a twitch shooter. The faster person wins.
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249251
my ping is usually 100ms so 10ms input lag doesn't matter for shit to me
20 ping here. I notice it. A lot. Anything under 150 is noticeable for me
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249265
definitely milliseconds, didn't notice much. I'm sure once I'm out of college and can afford a 144Hz monitor i might care
If you don't play games such as Dota 2, CS:GO or SC2 then you are not likely to notice but 1 frame there is the difference between victory and defeat.
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249289
lmfao you dont need a 144hz monitor for dota or sc2
In bronze league maybe :). Koreans can issue 250 commands per minute. 144Hz is a BIG factor for them.
https://linustechtips.com/topic/639692-fps-sudden-drop/#findComment-8249296
