Hey guys
Pc specs:
I7-6700K
Asus VIII Ranger
16 gb Corsair Vengeance 2.166
GPu hasn't arrived so i use the Integrated graphics for now
corsair RM 750 X
The problem is i have to connect it to my tv for now (Samsung smart Tv) cause my GPU and monitor haven't arrived yet. But i get no screen and get the errorcode 99 ( Super IO Intialization ).
i have disconnected and reconnected everything. I have reset CMOS and so on and still no process. Does anyone know how to fix this? did i break something in the building process ? I'm really worried because i spend everything on this pc ;(
EDIT : THe pc is just built. no OS or anything
https://linustechtips.com/topic/639626-problem-booting-up-pc-on-tv/
Some TVs like my old one had a menu option for PC so it would allow you to auto adjust the screen. Kind of reminded me about degause for old monitors but it was an led panel tv. check your menus for PC options. If thats not the case you may need to go into your computers display settings and check if it is detecting a screen.
Are you trying to just go from HDMI out on your PC to HDMI in on your TV?
It is a new build and i'm trying to boot it up to install OS. i don't have a monitor so i use the tv. But it doesn't show anything if though i connected it to the right slots
Are you plugged into the graphics card? if you havent installed an OS yet, you may need to hook up your screen to the motherboard. Without the drivers it may not have the graphics card as the default.
My GPU hasn't arrived yet , but i wanted to install all the drivers but it isnt working apparently. I think i broke something.
do you have a way to upload a clear picture of the PC you can post here?
 Check all your connections and make sure they are fitted correctly.
 Check that your fans are spinning when powered up if there is no power LED.
atm i have giving up and i'm going to bed in a depressed mood. Tommorow i'll try, but i'm just really sad.....
