I think there's a problem with my hardrive, I'm currently using a 2TB HDD combined with a 250GB SSD, but any games that I run on the HDD lags extremely bad, some not even able to open. As soon as I move them to the SSD it's fine, does anyone know what's the cause/fix for this issue?
Any help is appreciated, also I can provide the specs or any other information that you may need.
https://linustechtips.com/topic/639428-hardrive-problems/
Open your command prompt in admin mode and run the following
chkdsk (Drive letter): /F /R
EXAMPLE
chkdsk c: /F /R
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/639428-hardrive-problems/#findComment-8246328
