Hello,
Specs:
CPU:I5-2500K
GPU: Asus R9 390 OC 8gb
PSU: Cooler Master 750w Bronze edition
HDD: WD 1TB Cavier blue
I am unsure of what is the problem here. So I decided to put it with CPU ect. Thread as I do believe this may be the problem. I am going to report what I have done in the past few days in a minute as this may help.
I installed another HDD from my old PC the day before this.
So today I installed the new Windows 10 Anniversary update and I believe this is where my problems are coming from.
Once this was installed I saw that new drivers were out for my GPU, I downloaded and installed these. I left it a while till I restarted as I was in the middle of doing something.
A couple hours later I decided that I wanted  to play CS (About 30 minutes ago)
I tend to get Max fps on the starting screen- 120 FPS
Although today I got 30...
I tried to unmax it, nothing.
Still the same.
I jump into a tdm
I still have 30fps and 180 ping..
So I restart my pc to install the drivers. Still no luck.
I look into my task manager and find a new service, System Interrupt.
I check the process and was on about 1.6% at peaked times.
I do WIN + R and run perfmon /report
These were the errors I got.
https://gyazo.com/8edf82dd8cb6572b99ba75d2bccfeb9a
I hope someone can help me! Thanks In Advanced.
P.S I have noticed that my GPU Clock is limiting alot.  It doesnt seem to go past 400mhz
https://linustechtips.com/topic/639223-pc-problems/
