Hello and i apologise for my bad english!!!!
i got a minor problem with my gpu  i can run anny game on ultra on windowed(full-screen)  but not on 144hz full screen  when i apply on anny other graphic settings low/med/high/ultra full-screen it freeze..  only fix is restart the whole sistem!
riig
cpu: i-5 6600k
gpu: Sapphire Nitro R9 390
memory:  16gb
psu: super flower titanium 1200w
motherboard : msi Z170A m5 gaming
cpu cooling sistem is on water corsair h110i gtx
 soo to be honest dunno why  in  Tom Clancy's The Division, Overwatch, Diablo 3, etc i can run them on anny settings while they are on windowed (Full-Screen) but not on normaly Full Screen  144hz   beside cs go ..... please help
https://linustechtips.com/topic/638949-gpu-problem/
riig
cpu: i-5 6600k
memory:  16gb
Update the graphics drivers
if (you want to reply) {
 USE THE QUOTE BUTTON
else {
 DONT
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241049
Just now, andrei112 said:
today i did a full reinstall of drivers ..  and still same problem
Search amazon for the monitor you're using see if other people are having the same problem
else {
 DONT
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241066
LED ASUS Gaming VG248QE 24 inch 1ms Black 3D 144Hz
is not the monitor tested on another gpu and working without problem
Try running your games at lower refresh rates or resolutions. If it fails try reinstalling windows as some software could've caused the problem
else {
 DONT
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241085
even if i do it on 50 hz still freeze just the game ... even if i'm on ts/skype/discord/ youtube   it works i can hear the game menu but the image freeze on graphics.....
the windows is fresh yesterday reinstalled..
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241099
First try connecting to Intregated graphics and run your games or stress test see if it crashes.
If it does it's probably not a GPU problem.  Run memtest.
If it doesn't it's a GPU problem.first make your PC freeze. Then go to event viewer and find the error code with which it crashed. Google the error code and hopefully you'll find a fix.  Otherwise If you still have warranty send it to sapphire
else {
 DONT
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241114
ok thx il try if not warranty is the last resort or might be cuz of the games i saw some similar posts  with other gpu's aswell ..   from nvidia and amd aswell ... and  like 95% off them high end gpu's/ rigs
https://linustechtips.com/topic/638949-gpu-problem/#findComment-8241139
