Where did you get that from? Bios or something?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233407
its from NZXT Cam, a free hardware monitoring program from NZXT.
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233411
more specs on the PC  please...i suspect it's a software problem if your PC isn't acting up...
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233421
You can basically see my specs in my signature.
i suspect that theCore 2 Quad is drawing too much power, but I haven't seen any problems yet.
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233430
Any idea what the PSU is? Brand and Wattage?
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233457
Its a proprietary PSU from Dell. Search up Dell Optiplex PSU.
i thinkl its the Mobo, but i can't find enough info on it to be sure.
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233468
Probably is fine, if it ain't broke then don't bother fixing it :D
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233478
I mean, I wasn't expecting much. I thought it was going to break when I put that Quad in.
And if you look at the mobo specs, its supposed to only support up to 4gb of RAM. Its been on 8gb and using all of it. Dell LIES. :D
But i am wondering if its reaching its full potential. It clocks up, and performs, but I dunno.
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233520
probably is fine :)
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8233526
Some voltages always read negative, try HWmonitor and see what it says. It should be just fine though
Troubleshooting a pc will make you believe in gremlins.
--Thread killer--
https://linustechtips.com/topic/638252-is-this-a-problem/#findComment-8234389
