Hello
I actually don't need much, I just need you to tell me what to use and what not to use and if it is good for me.
My setup is mainly used to edit photos (Adobe Photoshop), Videos (Adobe Premiere) & some gaming.
I attached a PDF file which shows the specs of my setup.
The link redirects you to my product list on Amazon.
https://amzn.com/w/AKSJK8WVZO45
Specs.pdf
https://linustechtips.com/topic/638199-my-setup-need-advice/
psu is OVEROVERKILL. A 430 watt is more than enough. Also, even though premiere is cpu intensive, I would recommend something like a gtx 950 for cuda acceleration. You also may want 32 gigs of ram. You can also shave money by getting a hyper 212 cpu cooler. It is the BEST cooler for under $80.
https://linustechtips.com/topic/638199-my-setup-need-advice/#findComment-8232837
Use pcpartpicker.com for your build. It'll make everything a lot easier.
A list of what you should change:
  • Change th GPU to something like a 1060. Premier can be GPU accelerated so that will help with rendering times
  • That PSU is SERIOUSLY overkill.... You do not need a 1000 watt psu... 650 is more than enough
  • Get 2 sticks of ram. Since you're video editing the extra bandwidth will help
  • Get a 7200 rpm hard drive. They're a lot faster than a 5400 rpm one
If you're thoroughly confused and not sure what I'm saying, give us a budget for your system and me or someone else will get you a parts list going.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/638199-my-setup-need-advice/#findComment-8232846
