USB wifi or built-in wifi card for ITX build
Hi Guys, Need a little help with wifi xD
I'm building a simple gaming and productivity ITX build and need to use wifi, as cable is out of the question (it's complicated).
I'm going to get a discrete gpu so I can't install a pci-e wifi card.
My question: Should I go with a USB wifi adapter or get a mobo with built in wifi? Recommendations pls. TY
Build Spec:
Intel i5 6500 (Not into overclocking)
Fractal Define Nano S
Fractal Integra M 550W
8GB DDR4 Kingston Fury RAM (Single Stick)
Kindston UV400 SSD 120gb
1TB WD Blue/Black
MOBO (undecided)
GPU (undecided)
Games Played:
CSGO
RUST
GMod
C&C
etc.
Application used
Photoshop and Premier
Get the cheaper option. They are practically doing the same job, connecting you to the router.
I'm part of the "Help a noob foundation"
Personally I'd go with a PCIe Wireless N/AC card - pretty cheap and keeps the outside of the case neat.
What might be the deciding factor is how far from your wireless access point you are - PCIe cards or built-in cards tend to have external antennas which will get a better signal than USB.
I'm a bit more that 5 meters away from my router with a wall in between my pc desk and the router, (it's in the next room across the hallway). However, I usually get full/almost full signal throughout most the house with my laptop/phone.
The cheapest option would be using USB wifi dongle. As I already have one from my old laptop. It's a D-Link DWA-127 150Mbps USB dongle with anthena, it worked fine for a bit, till the laptop died.
In that case a USB one should be fine :)
