Need help picking a gpu
Go to solution Solved by AlTech,
3 minutes ago, Chadmasta5 said:
Hello.
I was wondering if anyone could help me pick out a cheap gpu to help cut down on video rendering time. This is the system I use. I know it's fairly old but it does the job fine. I use cyberlink powerdirector 12 which has support for gpu acceleration and I need an amd card as it's the only bramd that supports mpeg 2 encoding with cyberlink.  I'd preferably have it be around $50 US but I'm willing to pay a little more if I have to. I also need one that works without external power as I only have a 250 watt power supply and I don't have much room to upgrade that. Sorry if my requests seem outlandish but I'm a bit new at upgrading a pc.
if you extend your budget to around $100 then there's the RX 460 which is brand new from AMD. It consumes very little power and might be what you're looking for,
Hello.
https://linustechtips.com/topic/637859-need-help-picking-a-gpu/
Hello.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/637859-need-help-picking-a-gpu/#findComment-8229412
Looks like it's still got a few days before release. I  may have to check it out. Thanks very much.
https://linustechtips.com/topic/637859-need-help-picking-a-gpu/#findComment-8229661
