Recently i bought a new cpu heatsink and i neglected to look at how tall it was and ended up with a 166mm tall heatsink.
funny enough my case only supports up to 160mm and i'm not going to leave my side panel open.
I've been thinking between the fractal design r5 and the bequiet silent base 600
the silent base has more reviews of being the more silent one
and the r5 is known to be customizeable which comes in handy.
my current gpu is 280mm long so the gpu won't be a problem.
if anyone could give me tips or know any other cases for absolute silence i would be happy to look at those.
i'm european so ordering from newegg will be hard or not even an option. my budget is 100-110 euro's which is about 110-120 dollars.
https://linustechtips.com/topic/637518-cant-decide-between-two-silent-cases/
3 minutes ago, GrassyAss said:
Both are excellent cases. Get whichever looks better to you or is cheaper.
Other systems I've built:
Bequiet is around 95 euros with the orange accent one idk why the full black is 5 euros higher but the r5 is about 105 so the price isn't that much. the bequiet one comes with their own fans installed 1x 120mm and 2x 140mm if i'm right. also the define r5 is a tad lower in height
7 minutes ago, Shd0w2 said:
Both are great, likely the Be Quiet is quieter because I believe it comes with their fans, which are optimized for silence, of course.
The only thing that bugs me is the rubber hdd stripes. the r5 simply screw and slide em in. the bequiet one is limited to 3 drive and idk where to get more of those stripes
Likely from their site in accessories or something
Diamond 5 in League :)
I just rebuilt my rig into a Define R5 coming from a HAF 922 and holy crap I didn't know how quiet things can get. This thing mostly cable managed itself. I needed 2 cable ties the rest was done with the velcros included. This thing looks so much cleaner it's heaven to build in and whoever considers getting it I can just recommend.
Addition: Temperatures are higher than they were in the HAF 922 (obviously) but since I'm still rocking a GTX 460 that was kind of expected with that tiny fan. Expect it to be better with a 1060 from MSI (hopefully) that I'm planning to get later this year.
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
find out that bequiet's hdd stripes are hard to get i'm leaning towards the r5 now aswell. it does look sleek and nice.
i've also looked on a couple of retail store and none of them sell the hdd stripes.
They should sell replacement parts, if they don't you might want to contact their support and ask about the hdd stripes and if they can send you some more.
I'd get the R5 just because the bottom dust filter is accessible through the front and also covers the whole bottom.
idk why but bequiet won't let me make a forum account and ask a moderator.
the only thing left to do is probably email them myself.
There should be a support section to make a support ticket.
this just pulls me more into the fractal design side, although i do like the silentbase
What pros do you actually see for the Silentbase?
23 minutes ago, GrassyAss said:
Silence and the included fans
Some say that the silentbase is more quiet than the r5 but that's just a fraction of a decibel
Would that be enough of a reason for you to go with the Silentbase?
1 minute ago, GrassyAss said:
well, not really since it's a hassle to gather the rubber stripes.
Have you seen the Hardware Canucks review of both cases?
Well, the price segment you're looking at has sooo many great cases... Enthoo Pro, Mastercase 5, Define R5, etc. If you want to go for silence though, I really would go for the Silent Base 600, which also has the added advantage of being somewhat more unique, as it seems that these days everyone and their dog has a Define R5. :P
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
i just can't choose lmao
ofcourse, he's one of my favourite reviewers.
That is very interesting for me to see!
