Need Help Choosing
thedawnarts
I'm looking into buying one of these but since they are pretty much the same I was wondering which one would you choose?
ASUS ROG SWIFT PG279Q 27" Screen LED-Lit Monitor
https://www.amazon.com/SWIFT-PG279Q-Screen-LED-Lit-Monitor/dp/B017EVR2VM?ie=UTF8&tag=pcpapi-20
or
Acer XB271HU bmiprz 27.0" 165Hz Monitor
http://www.bhphotovideo.com/c/product/1212852-REG/acer_um_hx1aa_001_xb271hu_bmiprz_27_widescreen.html
Thanks as always!
Hey, so I would go with the Acer Predator XB271HU because I have used both and even though they are basically the same monitor. I prefer the colour on the Acer Predator more because of the fact that it is a lot more immersive and is an absolute dream to play on whilst gaming. Good luck with it all and hope everything goes well!
Kind Regards, Christian
1 minute ago, chris76816 said:
Which one do you think you will choose?
I honestly don't know, depends on what people say and which one is available when I decide to buy. etc..
  • 3 weeks later...
On 8/2/2016 at 11:18 PM, chris76816 said:
Ok sounds good. Their both good monitors anyway.
Finally bought the monitor :) I went with Asus because one it was the only one in stock and two hearing the stories about Acer's customer service was terrifying and I don't wanna go through that if I have to. Will be here in two days!
