Hi guys,
Got a Gigabyte G1 GTX1070 and i've overclocked it to +110 power limit, +100 core clock and +200 memory clock.
Valley bench runs great, but when i play Far cry primal for example, after an hour or so the screen freezes and i need to restart the computer.
What am i doing wrong?
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/
what about temperatures? monitor them during gameplay that sounds like something is overheating.
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219822
1 minute ago, Maist said:
Not likely.
It's 60-70 max, never goes above 70.
I would try with no vram overclock, those things get even hotter when playing games rather than stress testing with (furmark etc.. )
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219850
Just now, Maist said:
Nope, this problem disappears
Then it sounds like your OC isn't stable. Increase your core voltage to max and try again, if you don't crash anymore reduce the core voltage bit by bit till you do. If you do this keep an eye on your temps, increasing core voltage will cause things to get toasty.
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219853
1 minute ago, LeapFrogMasterRace said:
Did you overclock the memory the same time as the gpu core clock?
read again.
My Build:
I7 4770k(3.7Ghz)(Watercooled, Astek 510LC)/Asus GTX 1070Ti Strix Advanced/1600 MHz DDR3 12GB/ASUS Z87-M G30AB/Kingston RBU-SC400S37128G 128GB SDD/Toshiba DT01ACA100 1000GB HDD/Acbel R88 ATX12V 700W /Windows 8.1 64 Bit
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219856
Just now, Kadleli said:
read again.
oops missread
My Build:
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219861
Oh you guys are probably right.
I've noticed that with the default curve the gpu runs at 30% when on 50C, thats probably why it crashes.
It it fine to set it so when it reaches 50c the fan will work at 50%, 60c - 60% and so on?
absolutely, you can have even more aggressive fan curve so you can overclock further
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8219906
4 minutes ago, Maist said:
Hi guys,
Still freezing, even though i did a custom curve and the GPU wont go above 55c.
any ideas? :(
Don't use Valley for GPU stability - Use Heaven instead, its much more likely to show instability.
CPU - i7 6800k @ 4.2Ghz
Mobo - Asus X99-A-II
Ram - Corsair Vengeance LPX White 32GB @ 3200Mhz
GPU - MSI GTX 1080ti Lightning X @ 2063/12528
Storage - Samsung SM961 256GB, Samsung 840 Pro 250GB & Sandisk Ultra II 256GB
Cooling - Corsair H110i (2x ML140 White LED)
PSU - RM850x
Case - Anidees Ai Crystal
Monitor - Acer XB270HU bprz @ 1440p / 144hz IPS
Sound - FiiO E10K & AKG K712 PROs
Peripherals - Razer Blackwidow TE & Corsiar Scimitar
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8223090
Did you loop it or only one run? Have you got any games that use the Cryengine to test it with?
PSU - RM850x
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8223151
only tested it in rainbow six siege and far cry primal so far.
R6 runs great, far cry freezes.
and i did only one loop.
by the way, what is the default temp in which the fans start spinning (gigabyte default curve)?
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8223158
Mine start to spin at 60c on default. I've changed it to 55.
PSU - RM850x
https://linustechtips.com/topic/637001-what-am-i-doing-wrong/#findComment-8223830
