Short question, hope sombody can help me.
I am searching for something like a Display Switch
In my case i want to use my PC for my Workstation and for Multimedia, but i want the Workstation in another Room
I can pull HDMI or DP or Thunderbolt cable through to the other Room but cable lengh will reach about 30 meter
I don't want all Display's active at once either the 3 monitor's for Workstation or the other three for Multimedia
I want on each side a support for 3 monitor or TV's
Lan is already in both Rooms
Hope you can help me along
Greetings Schoergi
https://linustechtips.com/topic/636761-display-switch/
The best and easiest option would be to use something like TeamViewer. It's also free and you won't need to physically connect your display. Issue might be using multimedia/games via this method but for working on files - just fine.
Physical HDMI cable won't go too far. I have one 15m cable I believe. Not the best option, unless you can find some amplifier. But then you need kb/mouse anyway.
https://linustechtips.com/topic/636761-display-switch/#findComment-8217113
