New built pc problems help
Go to solution Solved by Poohl,
Just now, Poohl said:
It's obviously none of those.
if you are using the GA-Z170N, its next to your 24-pin power connector.
My pc wont run nothing is responding only the header lights and gpu gtx 970 but its not running only glowing i the mobo i have is z170n wifi gigabye ultra durable and an skylake i5 and corsair 700 wats psu i have tried the pc before but with other mobo and everything worked flawlessly now nothing wants to respond im pretty sure i did the pins correctly and i did check the cables from the psu to the components and the only thing i have hooked up to the pc is the psu cable and yes the mobo is an mini itx mobo thanks please help
CPU:Intel Core i5 6600K 3,5GHz  Motherboard: Z170 PRO GAMING  RAM: HyperX X Fury black DDR4 2x4GB
GPU: AMD Radeon HD 7800 series Case: some random shit tho it is gonna be upgraded Storage: SanDisk SSD Plus 240GB Cooling: Cooler Master Hyper 212 Evo Display: Asus VS278Q Keyboard: Roccat Arvo Mouse:Razer Naga 2015 Edition OS:Windows 10
https://linustechtips.com/topic/636293-new-built-pc-problems-help/
Is it beeping?
Try the IGpu.
No it is not beeping and i took out the gpu so i could have it easier for now to switch around if something is wrong so im on on board gpu for now bit it wont launch or beep
3 minutes ago, Poohl said:
If it is able to beep (has speaker) and doesn't, it might be dead.
does it have any LEDs indicating anything (the mobo itself).
This ?
1 minute ago, Poohl said:
yes, that should be pugged in somewhere and beep. if it's not you got a serious problem. Mobos beep even without CPU.
I assume you checked all cables.
Yes
Its in but nothing is spinning in im sure that i sis the pins corectly
well than I'd recommend using your old Mobo.
Thats the pin that ive connected and i think that correct
I dont think the mobo is dead cuz it gives power to gpu and the chassi
9 minutes ago, Poohl said:
You fucking hero man
