HDD Device not found in Bootable devices, nor bios, or anywhere. Please help.
2 minutes ago, Scrulls said:
So i opened up the easy HDD access part of the case and checked if it was spinning...no it was not, so i took it off and reinserted it with a different Sata Power connector and Sata cable to a different Sata port on the Motherboard... voila, it has been found in Computer management finally as 931 GB of unallocated Space.
Question now is... how do i allocate it so i can use it.. ill try restarting and entering the BIOS storage partitions now, so should you have any tips, leave them here. Ill update this when its done.
If you want to use you have to open disk managerment(run diskmgmt.msc in the run window or start) and then right click on the drive and select new volume
Also the drive is 1000GB is also 931GiB and windows uses GiB
