7 minutes ago, ThePotatoGod289 said:
Hey guys
i am new to pc gaming and I am looking to build a computer. I have a budget of $750. Any feedback would be greatly appreciated. Thanks
https://pcpartpicker.com/guide/DND48d/modest-gaming-build
This one looks pretty good for you.
27 minutes ago, ThePotatoGod289 said:
Hey guys
http://pcpartpicker.com/list/P7dcqk a little over budget, but it's a good build!
What do you suggest for the operating system
Get windows 10, its $30 on a lot of sites. I got mine here:
https://www.gameveo.com/windows-10-professional-32-64-global-1pc-email-delivery-24-7.html?search=windows&description=true
Windows 10. but you have two choices. OEM key or a consumer key.
OEM keys you can get for $35 but you might have problems if you change hardware often
And consumer keys you can change your setup as many times as you want but its more expensive. $120 expensive.
https://www.kinguin.net/category/19429/windows-10-professional-oem-key/
I don't really trust kinguin, its quite easy to get scammed
1 hour ago, ThePotatoGod289 said:
Where do you suggest getting an operating system at
At any site that has customer service, but not like kinguin, they are known for scams. G2A is alright but i recommend gameveo or gamecheap. They have good service and thats where i got my key from.
