Problem
Solved by Whaler_99,
In the advanced view, when adding a GPU slot - the GPU Index is usually at -1 - which is the default - auto select. Set it to 0 and see which card you get. Then you can add the other, making that 1. If they still reversed, do it again, only now, to add the 770, make the first slot index 1 and the second 0.
That should work, although I have also seen where it doesn't ...
