Doesn't exactly work like that. What's your budget? What are you planning to do with this computer? Do you need peripherals? Do you need an OS?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
haha budget as low as you can get it no peripherals no OS and i plan to game with it stuff like cod or gta
I still need a budget. Realistically, what's the max amount of money you can spend on the build?
Still doesn't help. "low as you can get" Tell us a budget?
6 minutes ago, ElephantMane said:
mm we'll go with 400
Okay, this is what I managed to conjure up:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($47.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 8GB (1 x 8GB) DDR4-2400 Memory  ($32.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Asus Radeon R7 370 2GB Video Card  ($89.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($27.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($43.99 @ SuperBiiz)
Total: $401.42
Generated by PCPartPicker 2016-07-30 04:16 EDT-0400
Total: $401.42
would a 750 sc be better than the r7 370? because i can get the 750 for like 25$
That's not actually that bad of a price. However, the R7 370 will perform much better.
CPU: AMD Athlon X4 845 3.5GHz Quad-Core Processor  ($59.99 @ NCIX US)
Motherboard: ASRock FM2A88M PRO3+ Micro ATX FM2+ Motherboard  ($43.98 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR3-1600 Memory  ($29.88 @ OutletPC)
Video Card: Asus Radeon R9 380 4GB Video Card  ($144.99 @ Newegg)
Case: DIYPC M89-R MicroATX Mini Tower Case  ($25.99 @ Newegg)
Total: $396.31
Generated by PCPartPicker 2016-07-30 05:15 EDT-0400
