37 minutes ago, I-love-Tech said:
Well Hello everyone,
I would like to ask you guys first of all your opinion of my system, than would you recommend overclocking (if yes than how much and either or both CPU and GPU) ???
System info:
http://pcpartpicker.com/list/4RR4qk
Very nice system, you can overclock both your GPU and CPU but how much is hard to tell. Thats basicly a bit of a lottery.
https://linustechtips.com/topic/634530-my-system/#findComment-8193585
On 7/29/2016 at 9:00 AM, kwiksilver said:
Nice system, but you might have to consider what youre doing. If your just a overclocker trying to beat records... I dont know. But the gpu is fine to play almost all games with no problem, and the cpu is good for productivity, multiple monitors, and pretty average for most above average pc gamers
I'm not the heaviest gamer for most games (like GTA5)  I can easily be happy with even a stable 60 fps. I do due productivity next to the main monitor i do have an extra old lg 19" 4:3 monitopr which i only use for monitoring temps and having like a chat program on it. for me the main goal was to have a system which is strong enough for productivity, basic video editing, some gaming along with that it should last me several years without the need to seriously update.
https://linustechtips.com/topic/634530-my-system/#findComment-8201869
I think the gpu does not really need a significant overclock as it seams to do its job more than great stock. and i think I didn't win on the silicon lottery as so far especialy with the heat in my room nothing over 3.8Ghz is reasonable. I might be able to push it to 4Ghz, but i dont think its  worth it.
https://linustechtips.com/topic/634530-my-system/#findComment-8201891
