so i wanted to invest in a RAM cooler, i looked at the EK-SFD https://www.ekwb.com/shop/ek-sf3d-triple-point-evo-incl-modules and i have the ASUS X99 Deluxe II (8 ram slots in two different sections (2 sections of 4)) and i was wondering if i could put 4 sticks or DDR4 8GB a stick in 1 section of 4 slots and buy the Ram cooler and put it over the 4 sticks but i dont quite understand the 1-3 and 2-4 ram slot rule, would i be able to do this?
https://linustechtips.com/topic/634241-i-need-help/
I'm actually not sure. From what I know you're supposed to fill up grey first and then fill up black, but I really don't know for sure. You could try it and see, since the worst that will happen is that the computer beeps at you.
I will most likely not respond to you in a thread unless you quote me.
$500 PC | $800 PC | $1000 PC | $1200 PC | $1500 PC | $2000 PC | $2500 PC | $3000 PC | $4000 PC
Damnit Carl (My portable POS):
CPU: Core i7-6700HQ
Motherboard: Toshiba L55-C5392 Mobo
RAM: 8GB DDR3 (even though I have Skylake)
GPU: Intel HD Graphics 530
Case: Toshiba L55-C5392 Case
Storage: 525 GB Crucial MX300 SSD
PSU: Whatever power jack comes with it
Display: Some 1366 x 768 garbage + an OK 1080p monitor
Cooling: Not enough + an external laptop tray
Keyboard: The included one
Mouse: $4 Lenovo 3D Optical Mouse (not as bad as you (rightly) assumed)
Sound: The Skullcandy branding right under the power button should clue you in
Operating System: Windows 10 Home
PCPartPicker URL: pcpartpicker.com/i-wish-i-had-enough-money-for-a-desktop-my-laptop-is-so-sh*t-its-not-even-on-portablepicker
https://linustechtips.com/topic/634241-i-need-help/#findComment-8190141
Also, next time, please don't call your thread "I need help". Ironically, it actually hinders me from helping you and others because it means that I don't actually know what you need help with until I click on your thread and read through the whole post, which just wastes everyone's time, really.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/634241-i-need-help/#findComment-8190174
9 minutes ago, WCFreak said:
alright, so on the quad channel i would be able to run 4 sticks or still only 2?
Quad channel means that the slots are grouped to be 2 on each channel. If you fill slots that use the same channel you are potentially losing performance over spreading them over all 4 channels. That means that ideally you want to populate the slots with an empty one inbetween every 2 full ones.
Don't invest in a ram cooler, it's truly pointless.
sudo chmod -R 000 /*
https://linustechtips.com/topic/634241-i-need-help/#findComment-8190238
