Looks good in my opinion.
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/63420-build-opinions/#findComment-867470
I approve, especially the C70!
https://linustechtips.com/topic/63420-build-opinions/#findComment-867472
I would go with the R4, if you want to save 10 dollars http://pcpartpicker.com/part/fractal-design-case-fdcadefr4bl, but the c70 is pretty good case not going to lie
Also I would go with the Corsair RM series if you can spend 10 more dollars on a PSU, it will help with cables managing and PSU features
http://www.amazon.com/Corsair-Series-80PLUS-Gold-Certified-Supply/dp/B00EB7UITQ/ref=sr_1_2?ie=UTF8&qid=1381189150&sr=8-2&keywords=corsair+rm+series
Another option change CPU to 8350 and you have alot of money left to to pick up a 850 watt Corsair RM series PSU and a 240gb SSD
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/63420-build-opinions/#findComment-867474
Looks good, apparently XFX psu's are noisey from what i have heard but, solid build!
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/63420-build-opinions/#findComment-867480
Psst.. 8350
no.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/63420-build-opinions/#findComment-867517
Wait a while longer and go for a single R9 card, use onboard until the cards are released if you absolutely need the computer soon. I would also get an 840 instead of OCZ at that SSD price, I would rather go for Windows 8.
otherwise good
Error: 410
https://linustechtips.com/topic/63420-build-opinions/#findComment-867524
otherwise good
Eww, Windows 8. Only get it if you're planning on buying a touch screen monitor. As well, I love my C70, but for the love of god do the window mod.
https://linustechtips.com/topic/63420-build-opinions/#findComment-867578
No, you only "eww windows 8" because it has metro in it. You don't have to use metro and that alone isn't worth deterring away from the multiple improvements and performance optimizations.
I can't seem to understand why people hate windows 8 without a good reason. I moved to windows 8 and after 30 mins of researching and exploring it's no less usable or confusing than Windows 7. You can't just say no but only if you need one feature of it.
Error: 410
https://linustechtips.com/topic/63420-build-opinions/#findComment-867886
Slight Edits: http://pcpartpicker.com/p/1MA5C
Remove all stock fans. The h100i has loud stock fans.
2 SilenX fans for front intake, 1 for rear exhaust. Hyperboreas for h100i.
https://linustechtips.com/topic/63420-build-opinions/#findComment-872925
