try uninstalling the driver from device manager then install the latest driver from the manufacturer website.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/634130-wifi-wont-work/#findComment-8191402
11 minutes ago, RazerFX said:
Its crap windows 10. Go install linux on her computer and I promise her computer will work like new again.
This doesn't really help some people need windows.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/634130-wifi-wont-work/#findComment-8191859
I tried that already. I've even completely reinstalled Windows, still didn't work. I've even tried a different wifi card, to which it won't boot and says its unsupported. What do I do??
https://linustechtips.com/topic/634130-wifi-wont-work/#findComment-8195853
perhaps it is not supported at all (under windows 10). It might be hepful if you posted the laptop model number  and specs.
btw, even if windows says that your device is installed and working, it might not work at all. Something like that happened to me with a bluetooth dongle. Device manager said it was installed but it never worked. Installed win 7 drivers and it did.
https://linustechtips.com/topic/634130-wifi-wont-work/#findComment-8201682
