7 hours ago, TXshooter said:
Is it possible to run hard tubing to a water pump? And if so, can someone put a link to a good pump that can?
Yes you can do that if you want a separate pump/res unit something with a pump top like this would allow for that:
https://www.ekwb.com/shop/ek-xtop-revo-d5-pwm-incl-pump
https://linustechtips.com/topic/634108-pump-tubing/#findComment-8191195
