I wanna be able to use chrome and teamspeak on my secondary monitor while playing games on my primary, but when I hit shift tab in game to go to steam and switch to the other monitor and try and do stuff it minimizes my game, also when I open chrome on the second monitor it pops up on the first monitor?
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
https://linustechtips.com/topic/63367-dual-display-help/
I don't think there is anything you can do about it.
Some games don't minimize the game when you do it,some do.
If you can set the game to windowed fullsceen/borderless fullscreen, that sorts the issue out.
Also about chrome appearing on the first monitor, drag it over and maximize and close on the 2nd monitor, repeat a few times, it will eventually kick in and open chrome all the time on the 2nd monitor.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/63367-dual-display-help/#findComment-866597
there has got to be a way other than that... I hate windowed mode
https://linustechtips.com/topic/63367-dual-display-help/#findComment-867938
The monitor you play your games on is set to monitor 1, which is your main monitor, so when you click off this screen onto your secondary, it will minimize what your doing on your main screen... I have this problem and haven't found a fix just yet...
if you do let me know its really annoying lol
https://linustechtips.com/topic/63367-dual-display-help/#findComment-867944
No it won't be windowed...fullscreen windowed/borderless windowed, is the same as fullscreen (no border and the entire screen is filled) just it allows you to switch programs easily.
https://linustechtips.com/topic/63367-dual-display-help/#findComment-869352
