Hey everyone,
I'm attempting my first PC build. So it goes without saying, I'm a noob at this. I've done many hours of research and have landed on the parts I want to use. I'm going for air cooling and a quiet build.
http://pcpartpicker.com/list/tVpHBP
The thing I'm most concerned about is any clearance issues I may have with the Case, CPU Cooler, and RAM. In your expert opinions, will these parts fit? Will I run into any clearance issues with the cooler fitting into the case? What about the cooler blocking any RAM or ports on the motherboard?
Case: Corsair 400Q - Max. CPU Cooler Height 170
Cooler: Dark Rock 3 (the regular, NOT the pro version) - Dimensions (LxWxH) 73x132x160
Motherboard: Asus Z170 Delux
RAM: Corsair Vengeance LPX 16GB
CPU: i7 6700
Video Card: GTX 1080
Would it be better to go with a slimmer cooler, maybe the Shadow Rock Slim, for instance? It's dimensions are 52x130x161. But will that cool my CPU effectively?
Thanks for your help guys!
https://linustechtips.com/topic/633557-will-these-fit/
2 minutes ago, Nun Soup said:
Hey everyone,
CPU: i7 6700
get the k version trust me its worth the something like 20 bucks is wort it!
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181036
Compatibility Check: No issues/incompatibilities found
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181104
Thanks. I saw that the build passed compatibility check. But I had people tell me that it doesn't account for clearance issues among the parts. Are you saying the compatibility check does take clearance into consideration?
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181187
Potential Issues / Incompatibilities
  • be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler and NZXT S340 (White) ATX Mid Tower Case are not compatible.
  • Games owned: 62
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181200
Question. Where did you find this information? Also, I'm looking at picking up the Dark Rock 3. That's very different from the Dark Rock Pro 3.
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181223
I was using that as an example from my current build plan. At the bottom of your parts list it will list any potential incompatibilities.
  • Games owned: 62
https://linustechtips.com/topic/633557-will-these-fit/#findComment-8181236
