No SATA power
Go to solution Solved by arch_linuxos,
On 7/27/2016 at 10:25 AM, STRMfrmXMN said:
snip
On 7/27/2016 at 9:08 AM, lee32uk said:
snip
I ended up returning it to Amazon and buying an RM850i. Works flawlessly now. Thanks for all your suggestions and time!
I recently switched cases, and now I get no power to any SATA devices. My PSU is 850W EVGA G2. I've tried different cables, different ports, and nothing works. Perif works fine for my molex LED strips. HDD is not recognized in BIOS and no fans spin up (I have them all on the Phanteks PWM hub which is powered by SATA). Am I missing something, or bad PSU? I'm just confused because it worked fine two hours before I switched cases - not sure what changed.
If you want more details on what I have in case it helps just check my signature.
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/633457-no-sata-power/
4 minutes ago, spidsepttk said:
The drive might have been damaged while you were moving it from the old PC to the new one. Do you have any alternative way of powering it, for example a usb drive enclosure?
The thing is, it's also the PWM hub that isn't working. I have a 2.5" enclosure but that's it. I'll probably go get another to check on my way back from work though. Thanks for the suggestion!
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8178761
Just now, spidsepttk said:
No problem, let me know how it goes.
I will! Hopefully the drive didn't die lol. I only really had games and stuff on it though so it's not the end of the world if it did. I think its an issue with the PSU though - Amazon is sending me a new one right now just in case. I'm hoping something else works though because it won't be here until Monday... sigh.
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8178786
Ok, you really don't have a second power supply? I thought that everyone had some kind of crappy psu that came with a case, and was replaced immediately.
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8178805
Nope, this is my only one (first PC, so no left-overs). Case didn't come with one.
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8178836
Just now, lee32uk said:
Try building outside of the case and see if it is any different.
I did. Nothing spins up still.
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8178988
Does the power supply work with the tester adapter thing that you get ?
Everything else works - the computer POSTs and everything. Just have no case fans going and no hard drive (boot drive is M.2).
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8179007
Something tells me you plugged the modular cables in wrong. Can you send us a picture of the cable configuration?
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8179654
Sure, I'll send them once I'm home. I'm pretty sure they're in correctly though, it's hard to mess those up lol.
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8181175
snip
snip
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8194883
That sucks the 850 didn't work just got a evga500 psu
Be Vigilant or Jump Off
https://linustechtips.com/topic/633457-no-sata-power/#findComment-8198199
