Are small desk fans like http://www.ebay.co.uk/itm/USB-FAN-MINI-PORTABLE-DESKTOP-COOLING-DESK-QUIET-FAN-FOR-COMPUTER-LAPTOP-PC-/370864153611?pt=UK_Home_Garden_Hearing_Cooling_Air&var=640109627384&hash=item565939e40b
loud / push any air what so ever?
Its so hot and I need something that isn't like a jet plain....to blow air into my face, dont want to brake the bank or one of them massive ones...no room.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/63331-small-desk-fan/
You could make one form an old computer fan and some cheap 12vDC supplies.
Don't really have any fan's which dont buzz/tick or that push any air really
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-865994
That thing is designed for "little people", i would say that buy one noctua fan and few fan extension cables. :)
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-865999
Are you looking for a real fan or like a USB fan?
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866003
or a bitfenix spectre. or a delta fan, for ultimate quietness.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866011
Any really, just something that is small enough to just sit on my desk (don't want the ones which are massive), and that isn't THAT loud and pushes decent amount of air without my wallet crying at me...
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866013
yep, or he can buy one CoolBeans to get ultimate cooling experience. ;)
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866019
Any really, just something that is small enough to just sit on my desk (don't want the ones which are massive), and that isn't THAT loud and pushes decent amount of air...
i like your mythbusters title
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866022
Who wouldn't...
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866027
Depending on the size of your desk you may want a USb fan. The desk fan I have is too big to fit on my desk its more of a bookshelf or dresser fan if you ask me.
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866066
A fan just to blow more hot air on your face?
I has a window next to me :D so it can blow in cool air from there ;p
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866072
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866080
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-866088
I've got some cheap fan I got at walmart, it's not USB, but it works fine for me. (I live in The Dirty South, it gets hot here)
AMD FX-8320 @ 4.3 ghz | Corsair H60 (Push/Pull)|  8GB Kingston Hyper X DDR3 1.6 ghz | Sapphire HD 7870 Oc'd | Biostar TA970 MOBO OCZ 750w  PSU | 2TB HDD + 120gb Kingston V300 SSD| Coolermaster CM Storm Enforcer Case | SoundBlaster Audigy SE  Windows 7        "I am a leaf on the wind, watch me..."   "You know nothing Jon Snauhh" "Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way."
/Steam Profile/Folding@home stats/TekSyndicate Fourms/  \m/  RIP David Gold (1980-2011) \m/ RIP Peter Steele (1962-2010) \m/ RIP Chuck Schuldiner (1967-2001) \m/ RIP Dio (1942-2010) \m/ RIP Cliff Burton (1962-1986) \m/ RIP Dime (1966-2004)
https://linustechtips.com/topic/63331-small-desk-fan/#findComment-867845
