Possible bottleneck in PC hardware
By
Zaheen117
in Graphics Cards
in Graphics Cards
Solved by Joshi_bo,
37 minutes ago, Zaheen117 said:No v-sync was turned on in all the instances mentioned above
V-sync locks the framerate to the refresh rate of your monitor to eliminate screen tearing. Try turning v-sync off and see if that helps. An i5-2400 will bottleneck a 1070 a bit but not by a huge amount do you should still be able to get higher than 60fps.
6
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking15 -
apoyusiken ·
Posted in PC Gaming7
