Fan controller or plain fan headers?
Solved by MrDrWho13,
1 hour ago, goof doofus said:What fan headers do you choose? Will I be ok as long as the fans are close to the headers? I want to be sure the correct temps are being measured.
I have one of the cheaper motherboards where all case fans are controlled together, and the CPU fan is separate.
As long as you plug the connectors in near where your fans are, and don't plug a case fan in the CPU fan slot, you should be fine. The manual will usually specify anything you're not sure about.
