does anybody know what the smallest atx case is that is black and has a side window? please include a link
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/632700-most-compact-atx-case/
Do you want a tower case, a cube case? I mean there are a lot of cases out there. Also may I ask why you want a really small full atx case?
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8167219
Lian Li PC-A51: classis tower-style case, but with the psu in the front:
http://www.lian-li.com/en/dt_portfolio/pc-a51/
Or if you prefer a slim design: Lian Li O7S:
http://www.lian-li.com/en/dt_portfolio/pc-o7s/
Ryzen 5 5600, 32GB DDR4, GTX 3070Ti, Acer Predator x34
InWin 901
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8167225
To clarify, you want the smallest case that is ATX form factor, and not a small case like an ITX form factor?
If that is the deal, then fungal may have hit the nail on the head just now. the 400C is a pretty good option. the 450D as well from corsair is good.
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8167303
i cant find any am3+ mini itx boards, and most matx cases ive seen are about the same size as full atx boards
Thanks guys! I think that i will probably stick with the 400c, since the lian li case is a little out of my price range...;)
SPECS:
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8167526
I wouldn't recommend buying an fx cpu at this point. I have nothing against amd and I own two fx cpus, a 4350 and a 8300. Both are great cpu's, but they are so old at this point, it would be like running out and getting a 2600k for a brand new pc, just not worth it. Also an i5 6500 with an h110 mini itx board will solve your sff problem, just saying.
And if you REALLY WANT AMD, am4 is coming up in the next few months and those cpus if anywhere near rumor, would be definitely worth looking into
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8173709
Dont bother getting FX because they're already very outdated and you can go mITX with Intel. Also, no ITX motherboards because no space for a north and south bridge.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/632700-most-compact-atx-case/#findComment-8173921
