Eh, power supply calculators are just random number generators most of the time. What are your specs?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
go to pcpartpicker.com and put in your specs and it should tell you at the top the total power draw
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
Just now, wagaloo123 said:
i5-6600k and r9 390, 8 gbs ram. I was thinking 500W?
I'd be thinking 550-650W just for the headroom. What power supply are you planning on getting?
http://www.microcenter.com/product/457414/500_Watt_80_500_Watt_ATX_Power_Supply
Not super fancy, I know, but reviews say it has bulletproof reliability and holds up for long periods of time. (And I'm on a relatively tight budget)
Horrible power supply, it's essentially bottom tier. Since you're planning to get a i5 6600K and a R9 390, you can afford to get a better quality one.
This one at the very minimum: http://www.ncixus.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX
Well, if my Kill-a-watt is accurate, my i7 4930K overclocked to 4.5ghz, and my R9 390X, with both stressed full tilt, it still doesn't pull more than 490w out of the wall. :P  but for that reason, you'd want at least 600w so you have sufficient overhead for any major dips and such
How about this one: https://www.amazon.com/EVGA-Bronze-Power-Supply-100-B1-0700-K1/dp/B018JYHBE6
I know it's a little overkill in terms of wattage but it gives me room for CrossFire in the future, and it seems to be a very good deal.
No, it's a bad power supply for Crossfire. Besides, Crossfire (and SLI) sucks and you're better off with a single stronger card than two weaker ones if you're planning to upgrade.
Out of all of the EVGA PSUs, get one from the B2, GS, G2, GQ, P2 or PS lineups.
